| Area: | Platform Tools |
Problem Description
When I use the reload button locate in the Drawing Production tab in a model, the attached reference disappears. To make it visible again, I need to reload the drawing. How can I fix this?
Steps to Resolve
Please check if the drawing is referenced in a 3D or 2D file. The recommended workflow is to assemble whole drawing in a 2D file, and then reference a 2D file to a sheet. If the file is referenced in a 3D, this may cause unexpected results.
