| Area: | Architectural Design | ||
| Subarea: | Parametric Cells |
After placing a component that uses either a PAZ or BXF cell, can it be modified without having to replace it?
1. In order to modify an existing component that uses a PAZ or BXF cell, first select the element using the Building Element information tool:
2. Click on the Parametric tab and press the Edit button:
3. At this point either Parametric Cell Studio or Parametric Frame Builder should automatically open, depending on the underlying cell format chosen.
Note: Both of these tools are also accessible from the Backstage by choosing File > Parametric Content:
