| Version(s): | Connect Edition | ||
| Area: | Slabs |
While upgrading datagroup schema, the legacy slabs are getting upgraded to compound slabs.
Step 1: Hover over to slabs to check the slab level.
Step 2: Once you are able to determine the level name, go to level manager and then lock that level.
Step 3: Now if you upgrade the datagroup schema, notice that the slab has not been upgraded.
