| Area: | Import/Export | ||
| Subarea: | i-model |
The properties on elements in an i-Model file opened using a ProjectWise managed workspace do not match the properties on those same elements when opened outside of ProjectWise.
There is an ECSchema.xml file in the local machine's workspace and one in the ProjectWise managed workspace.
The ECSchema.xml file on the local machine contains data which is not present in the ECSchema.xml file in ProjectWise, so the two files are “out of sync”. The file in ProjectWise must be replaced with the client machine version in order to sync up so the same information is copied into the I-Model file created in ProjectWise.
Following are the steps to resolve this issue:
Note: The configuration variable BB_DG_ECSCHEMA_CACHE is by default defined as $(BB_WORKSET_SETTINGS).
