| Area: | Drawing Views | ||
| Subarea: | Generate Callout |
You might notice that not all the Plan Drawings you created have Section Markers and the option to Show Callout is not available in the Drawing Model.
This is because Markers are designed to display only when they intersect with the reference Plan Saved View. This guide provides steps on how to generate Section Callouts in all Plan Drawings.
In the above example, the drawing and sheet models are in the same .dgn file while commonly, the drawing and sheet models are in a separate .dgn file. For the latter, importing Saved Views is required.
You need to open the Plan Drawing Model, open Saved Views dialog, and Import Saved Views Selecting the container model .dgn or the .dgn where the Section Saved View is created. After importing, follow Step 2 to Generate Callout. You can watch the video below which shows the workflow.
