| Version(s): | CONNECT Edition (10.08.00.xx) and above |
| Environment: | N/A |
| Area: | N/A |
| Subarea: | N/A |
| Original Author: | Vikrant Kale , Bentley Product Advantage Group |
Bentley Raceway and Cable Management's Raceway and Underground System design tools are now included with OpenPlant Modeler CONNECT Update 8. You can elect to install these design tools during the OpenPlant Modeler product install.
This document will guide you on the steps to enable the Bentley Raceway and Cable Management's Raceway and Underground System design tools in the OpenPlant modeler.
Note: To utilize cable management features you will need to use this standalone Bentley Raceway and Cable Management application.
Prerequisite: Install OpenPlant Project Administrator.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
