Family/Part Editor, storing column display settings
 Version(s):CONNECT Edition
 Environment:N/A
 Area:Datasets
 Subarea:Family & Parts
The display of columns in the Family/Part Editor can be modified to show/hide desired attributes:
These changes are saved by default in TFDSExplorerSettings.rsc in the Setting folder of the active dataset, e.g. C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets\Dataset_SE\Setting.
This file can be relocated to another location, perhaps .../Organization/Setting/ (that folder would need to be added) or to a WorkSet. The variable TFDATASET_EXPLORERSETTINGS can be used to redirect it.
The path and filename must be specified, e.g.:
TFDATASET_EXPLORERSETTINGS = $(BB_WORKSET_SETTINGS)FPEditorSettings.rsc
Which resolves to:
C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces\Building_Examples\WorkSets\BuildingTemplate_SE\Standards\Setting\FPEditorSettings.rsc
