| Area: | Mechanical Design | ||
| Subarea: | Duct System Sizing |
Problem description
I want to change the units in the Duct System Sizing tool from Imperial to Metric. How can I do this?
If you are using a US Dataset, you will see the imperial units. When you open the settings in the Duct System Sizing tool, you can see which Unit System you are using, but you can’t change it. If you want to see metric units, you need to use different dataset.
