Product(s): | OpenBuildings Designer | ||
Version(s): | CONNECT Edition | ||
Area: | Mechanical Design | ||
Subarea: | Duct System Sizing |
Problem description
How is it possible to add pressure on flexible duct in Duct System Sizing tool?
In Duct System Sizing tool, double-click on “Summary of FLC” field, then an additional window will open.
If you change the value of the “Component Loss Override” field, then the “Total Pressure Loss” Value in the Duct System Sizing tool will change automatically.
