| Area: | General |
Problem Description
My text style should use Arial. If I change the text style back to Arial and sync it, it will match. What’s the solution?
When I want to use the text style in this file, the font automatically changes to MS Shell.
Steps to Resolve
There is a text in the active file where this text style uses the MS Shell library font instead of Arial. So both library fonts are out of sync.
