| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Workspaces and Worksets |
This article explains how to delete existing Workspace data, so that it no longer appears in the Workspace dropdown list.
To delete your workspace, first close your OpenBuildings Energy Simulator and then go to this location from your file explorer- "C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\WorkSpaces". After that select the workspace (you want to delete) and the corresponding .cfg file and delete it from there. Please refer to the screengrab below for reference.
Upon deleting the workspace, please restart your Energy Simulator and you will notice that the workspace will be removed from the workspace dropdown list.
