| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Installation and Licensing |
OpenBuildings Energy Simulator comes as standard as part of the OpenBuildings Designer installation.
OpenBuildings Designer consists of multiple engineering disciplines, such as architectural, structural, mechanical and electrical. The energy analysis of buildings is one such discipline incorporated via OpenBuildings Energy Simulator.
To use OpenBuildings Energy Simulator please install OpenBuildings Designer.
Note for Part L users:
OpenBuildings 2023 is the current approved version for Part L 2021 and 2013.
Further details can be found here.
Please note if you have a previous version of OpenBuildings on your machine you do not need to uninstall it prior to the below.
Step One: Download
You will firstly need to download the installer from: https://softwaredownloads.bentley.com/. Only your site administrator will have access to the downloads - to obtain access please contact your admin. Steps to obtain access yourself can be found here.
From the Brand dropdown, select OpenBuildings and then click Apply:
Select OpenBuildings Designer to proceed to the download screen. (Note there is only one OpenBuildings Designer installation - there is no particular one for OpenBuildings Energy Simulator). Select the latest version, and click Download:
Step Two: Install
Once downloaded, select Run and the below screen will appear. Here, select Configure to obtain your regional dataset (e.g. NM), as detailed in this article.
Then, to install, tick the License Agreement as below and select Install.
The installation will commence and after a few moments you should be able to open the software as shown here.
