| Area: | Platform Tools | ||
| Subarea | Variables |
When using any expression in OpenBuildings Designer, if any negative angle value was calculated that value does not reflect in the geometry.
To correctly reflect that negative angle value please follow the steps below:
1. If the ‘Negative Angle’ value is not reflected the in the geometry then the negative value can be defined using this expression:
2. There you will need another variable to choose when using ‘Positive Angle’ and ‘Negative Angle’ values. The name of the Variable will be the ‘Angle Condition’ and this is the expression used for it:
