| Area: | Architectural Design | ||
| Subarea: | Compound Slab |
Problem Description
When I try to place a Compound Slab in my newly created custom WorkSpace the Compound Slab dialog box is empty as shown in the below image. How can I fix this problem?
Please refer to the below mentioned steps to resolve this issue.
2. After you restart OpenBuildings Designer you should see that the Compound Slab placement dialog is fully populated and works as expected.
