| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Modelling |
Upon creating a new floor and importing your 2D floor plan, you may find that the scale is not correct. It may be off by a factor of 1000, for instance.
This occurs if the drawing in question users external reference files (or X-refs).
This means that when imported, Energy Simulator cannot find the data it needs in relation to the units, as this data does not exist in the file itself.
To resolve, either:
