| Area: | General |
Problem Description
How can I delete shared cells from AECOSim Building Designer V8i in OpenBuildings Designer CONNECT Edition? While attempting to delete them I am getting the error shown in the image below.
Please follow the below steps through which you can successfully delete AECOsim V8i shared cells in OpenBuildings Designer.
