| Applies To | OpenPlant CONNECT Edition |
| Version(s): | 10.06.00.23 |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Piping/Support |
| Subarea: | Placement |
| Original Author: | Soham Mhaskar, Bentley Product Advantage Group |
Placing a Support directly on Pipe is not possible. Although there is a way by which it can be achieved to place Support under a TEE and get it in Isometric Output after one generates Isometrics.
1. Place a Support on Pipe.
2. Move this Support placed on Pipe onto the Tee using "Move Component" command.
3. Hit Enter, execute a Keyin "mechaddin migratesupports".
[NOTE: Spell check while executing Keyin]
4. Go to Pipeline Manager & Generate Isometric sheet.
5. Observe that support comes up on Tee in the Iso sheet which is desired.
communities.bentley.com/.../drawing-flattener
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
