| Version(s): |
CONNECT Edition 10.08.00.51 (Update 8) |
| Environment: | Windows 8.1/10 (64-bit) |
| Area: | Spec |
| Subarea: | Component |
| Original Author: | Aishwarya Kulkarni, Bentley Product Advantage Group |
In OpenPlant Modeler for hand wheel, a user can modify hand wheel length (HANDWL_LEN) and diameter (HANDWL_OD) but there is not any option to modify the Stem Diameter of the hand wheel. The value of stem diameter is hard coded in the code and it’s dependent on the Wheel Diameter.
communities.bentley.com/.../how-to-get-inside-diameter-calculated-in-openplant-modeler-connect
