| | Product(s): | OpenBuildings Designer | |
| | Version(s): | CONNECT Edition | |
| | Area: | Platform Tools | |
| | Subarea: | Reference |
I want all reference files to display gray so the elements in the active file stand out.
- Go to File - Settings - Configuration - Configuration Variables.
- Click on the Levels category.
- Edit MS_LEVEL_EDIT_NESTED_ATTACHMENT_LEVELS and give it a value of 1.
- Click OK on the Configuration Variables dialog and Yes to Save the configuration changes.
- Exit the file and re-open it and you should be able to set Override colors on nested reference
