Product(s): | OpenBuildings Designer | ||
Version(s): | CONNECT Edition | ||
Area: | Import/Export | ||
Subarea: | IFC |
I have a IFC_Mapping_overrides.ifc2x3.set file and I want to upgrade/change it to work in IFC4, but I get an error that the “DataGroup property ObjectFireResistance/@Fire | Rating not found”. How to deal with this?
Open the IFC_Mapping_overrides.ifc2x3.set file and check its name.
Open the ObjectFireResistance.xsd file and compare the naming of the same attribute.
The part after @ in the set file should be changed to the Name attribute from the xsd file. Therefore, change the name in the set file to:
and Save settings.
