| Version(s): | CONNECT Edition Update 9 or later | ||
| Area: | Architectural Design | ||
| Subarea: | Space Planning |
Problem description
How can I change an existing Space to an Associative Space?
In OpenBuildings Designer Update 9 the Associative Space options have been added.
Spaces are often placed one way, and then later you need to change it to another. The Change to Associative Space toggle allows you to convert a space between Place by Flood and Manual methods of controlling the boundary. The Change to Associative Space functionality can be applied to closed spaces, shapes, and enclosed areas (such as walls).
Please see the video below demonstrating the workflow for better reference.
