| Product(s): | OpenPlant Isometrics Manager |
| Version(s): |
CONNECT Edition 10.09.00.74 (Update 9) |
| Environment: | Windows 8.1/10 (64-bit) |
| Area: | BOM |
| Subarea: | BOM report customization |
| Original Author: | Shubham Sawant, Bentley Product Advantage Group |
While following the wiki article how-to-combine-the-bom-in-isometric-with-certain-sequence for combining & setting the sequence in BOM report, it has been observed that, when settings is done in Rep-sortgroups.txt file, the supports field does not respect the definitions in the file.
Definition in file
Note that, supports is placed at last. i.e number 6. But, actual results in BOM is as shown
Notice that, though in definition the support is at number 6, in actual BOM its at 3rd place.
In this wiki article, we will see how to set the supports at the end of the BOM.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
