Applies To | OpenPlant CONNECT Edition | ||
Product(s): | OpenPlant Modeler | ||
Version(s): | CONNECT EDITION (10.xx.00.xx) | ||
Environment: | Windows 8.1/10 (64 bit) | ||
Area: | Component | ||
Subarea: | Placement | ||
Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Default configuration of OpenPlant Modeler only allows users to place components by Nominal Diameter. But there is a requirement from user that they want to place components by Actual sizes i.e. Outside Diameters. Below steps will explain the changes to be made in schema which shall allow you to place components by outside diameters.
