Applies To | |
Product(s): | OpenPlant PID CONNECT Edition |
Version(s): |
10.xx.xx.xx |
Environment: | Windows 7/8.1/10 (64-bit) |
Area: | Annotation |
Subarea: | Annotation |
Original Author: | Abhijit Bute, Bentley Product Advantage Group |
Sometimes, users may have a requirement to modify some components' properties in OpenPlant PID. Property values can be modified in several ways, one of the useful methods via Explorer.
By using the following method user will get all property values under one window, where modification can be done in one go.
Detail (items) window will Open, where desired property values can be modified.
