Technical requirements
The iTwin Synchronizer Portal does not require any client software or plug-in to be installed on your computer. Below you will find information about supported browsers to provide you the best synchronization experience.
Browser Support
iTwin Synchronizer Portal is supported on the latest versions of these browsers.
Data Center hosting information
iTwin Synchronizer Portal is supported in these data centers:
Data center will be chosen based on the ProjectWise project property called "Data Center Locations".
