Unrecognized Format
Table of Contents
Unrecognized Format
 Error: Revit_0004
Error Message: The input file format is unsupported. Please confirm that the file in the connection is a file with an .rvt file extension and that it can be opened in a version of Revit that is supported by the Revit iModel Connector.
Issue:
The connector assigned to this file does not recognize the file format.
Cause:
The error may occur because the file is not a valid Revit file (.RVT), is corrupted or damaged, has been incorrectly renamed with a Revit extension, or is a different format (such as IFC or DWG) that is Revit-compatible but not natively supported by the connector.
 Error: Revit_0005, Revit_0006
Error Message:
Revit_0005: The input file looks damaged, please try to reload from its original location. Or it may contain some unsupported Revit data fields, please send it to Bentley support for investigation if possible.
Revit_0006: The Revit file appears to be corrupted. Please try to open it in Revit and re-save. Try to use the latest supported Revit version if re-saving didn't help.
Issue:
Cause:
 Error: Revit_0007, Revit_0009
Error message:
Revit_0007: The Revit file has been saved in an unsupported Revit version. Please upgrade the input file by saving it in a supported Revit version if it was last updated with an unsupported version of Revit.
Revit_0009: The input file has an obsolete format and its data may be imported incorrectly. Please upgrade the input file by saving it in newer supported Revit version and re-synchronize.
Issue:
Cause:
The error may be caused by using a Revit file created in a version that is either too old (prior to the 2015 format) or too new to be supported by the current version of the connector. To resolve this, first check the file’s Revit version by opening it in Revit and verifying when it was last saved. If the file was created in an unsupported version, open it in a supported version of Revit, then re-save it to update the file format accordingly. If the file was created in a newer version not yet supported by the connector, consider saving it in an older, compatible version if possible. Additionally, confirm that the connector or plugin you are using supports the Revit version in question by checking its documentation or support resources. If the problem persists, we recommend contacting Bentley technical support and providing the file along with version details so they can assist further or advise on compatibility timelines. Supported file formats: wiki: Supported File Formats - KB0098377
 Error: Revit_0008
Error Message: Input file is not a Revit file. Please check the file for corruption or use another connector if the file is not a Revit file.
Issue:
Cause:
Use the correct Revit file or use different connector if the file is not a Revit file.
 Error: Revit_0038
Error Message: Input file is not a Revit file, but rather a ZIP archive.
Issue:
Cause:
Unsupported
 Error: Nwd_0006
Error Message: Input file (%s file format version) is not supported.
Issue:
The connector was unable to open the format.
Cause:
The Navisworks connector supports .nwd and .nwc formats, other formats like .nwf are not supported.
Make sure that the Navisworks models that are part of the connection have been saved either as .nwd or .nwc formats and re-try the synchronization.
