Connector Lock Error
Error message: "Connector Lock Errors"
Issue:
Cause:
- At this time, please Contact Bentley support for assistance to further diagnose this kind of error.
Error message: "iModel is locked by application"
Issue:
- Synchronization failed due to iModel being locked by another application.
Cause:
- The current synchronization is unable to proceed because another application has the iModel locked in order to make modifications.
- Normally, the locks will be cleared when the other application has completed its changes, and your synchronization should be able to proceed at that time. If the other application has completed and the locks are still present, please Contact Bentley support for assistance to further diagnose this kind of error.
