Supported File Formats
A wide array of design applications are supported in synchronization workflows, ensuring all your engineering data can be aggregated into a single digital twin environment.
If you are interested in iTwin Synchronizer Client supported connectors, here are the differences from the main list:
Design Applications File Extensions Connection Type iTwin Synchronizer Client Supported Versions
OpenRoads ConceptStation dgndb ConceptStation   10.0.15.138 and higher
OpenTower Designer otxml OpenTower not supported
AutoPLANT Modeler dwg AutoPlant not supported
Intergraph Smart 3D Review vue VUE not supported
ESRI File Geodatabase   Geo
Oracle Spatial   Geo   12c, 18c and 19c
PostGIS database   Geo
SQL Spatial Database   Geo   2019
VUE vue VUE not supported
If you do not see required connector, you can fill out the idea in your main design review portal ideas page.
The following table list the applications currently supported and the different ways available to sync the data to an iTwin.
Bentley Design Applications File Extensions Connection Type iTwin Synchronizer Application ProjectWise Supported Versions
 Client  Portal
AutoPLANT Modeler dwg AutoPlant   * 10.01.00.67 and higher
Bentley Raceway and Cable Management dgn MicroStation   CONNECT from Update 4
MicroStation CONNECT / V8i Editions dgn, i.dgn MicroStation   CONNECT / V8i Editions
OpenBridge Designer dgn Civil     CONNECT Edition
OpenBuildings Designer dgn OpenBuildings *     CONNECT Edition
OpenPlant Modeler dgn         CONNECT from Update 7
OpenPlant PID dgn         CONNECT from Update 7
OpenRail Designer dgn Civil     CONNECT Edition
OpenRoads Designer dgn Civil     CONNECT Edition
OpenSite Designer dgn Civil     CONNECT Edition
OpenTower Designer otxml OpenTower       CONNECT from Update 2
OpenTunnel Designer dgn Civil     CONNECT Edition
ProStructures dgn ProStructures***     CONNECT from Update 6
* Note that AutoPlant does not support legacy ProjectWise connections for Portal synchronizations.
**Note because of OpenBuilding Designers' requirement to run with a workspace OpenBuilding Connector is not an available option when using ProjectShare.
***ProStructure is embed inside multiple products like Open Bridge Modeler, OpenPlant Modeler. There is a limitation with connectors that only one connector can process one dgn so if the ProStructure components are inserted inside a dgn with the parent products components then the parent connector will take the ownership. It will publish the ProStructure components graphics but not the properties. So please make sure that ProStructure data is kept in a separate dgn when invoked from OpenBridge or OpenPlant.
3rd Party Design Applications File Extensions Connection Type iTwin Synchronizer Application Supported Versions
 Client  Portal
3D Studio 3ds MicroStation
AutoCAD dwg, dxf AutoCAD Dwg   2015 - 2025
AVEVA E3D N/A Open 3D     1.x.x - 2.2.x.x
AVEVA PDMS N/A Open 3D     12.0 and 12.1
AVEVA Review for PDMS/E3D rvm RVM
Civil 3D dwg Civil 3D   2015 - 2025
COMOS dwg AutoCAD Dwg*
Intergraph Smart 3D N/A Open 3D     2009.1 - 2016
Intergraph Smart Instrumentation N/A Smart Instrumentation     2016
Intergraph Smart P&ID zip SmartPlant P&ID   2014 R1, 2019
Navisworks nwd, nwc Navisworks   2013 - 2025
Revit**
rvt
Revit   2015 -2024
Rhino 3dm MicroStation
Sketchup*** skp MicroStation   2017-2022
* The AutoCAD Connector by default processes all files as 3D, however a flag can be set by Bentley to process files in a connection as 2D. If you wish to do this, please contact Bentley support to enable this flag. Additional exports to Excel files are required to get all of the available data from COMOS and that needs to be separately synchronized into the iModel and aggregated with PlantSight.
** The level of detail can be set for synchronizations from Revit. The default is to synchronize all data using the "Fine" level. The other options are Coarse, Medium. These options correspond to the options available within Revit views. Changing the default level of detail can help reduce the time it takes to synchronize Revit models, but will result in simplified geometry. If you wish to change the level of detail from the default, please contact Bentley Support and the level of detail can be set.
*** MicroStation does not currently support Sketchup text entities, so they will not be converted to iModel either.
† The RVM connector is only available for synchronizations created in Bentley Infrastructure Cloud and is currently in Beta. Please contact Bentley if you are interested in using this connector.
Interchange Formats Connection Type iTwin Synchronizer Application Supported Versions
 Client  Portal
ACIS (.sat)
MicroStation (via dgn)
  Up to 25.0
ArcGIS Feature Service Geo   10.6 and higher
Autodesk 3DS Max MicroStation
CGM MicroStation (via dgn)   1.0
DXF AutoCAD   2015-2021
FBX* MicroStation
Up to and
including 2011
Geojson Geo
IFC IFC
IFC2x3, IFC4, IFC4.3
IGES (.igs) MicroStation (via dgn)
2.0, 3.0, 4.0, or 5.0
fixed-length ASCII
i-model MicroStation
JT MicroStation (via dgn)   8.0 - 10.6
kml / kmz** Geo
Land XML MicroStation (via dgn)
MIF / MID
OBJ MicroStation
Parasolid (.x_t) MicroStation (via dgn)   Up to 13.0
RVM RVM   •***
Shape files (.SHP) Geo
Sketchup (.SKP) MicroStation   2017-2022
STEP (.stp) MicroStation (via dgn)
STL MicroStation (via dgn)
VUE VUE
Web Feature Service (WFS) Geo
* MicroStation does not currently support FBX custom properties, so they will not be converted to iModel either.
** KMZ files must first be uncompressed into KML before processing with the Geo Connector.
*** The RVM connector is only available for synchronizations created in Bentley Infrastructure Cloud and is currently in Beta. Please contact Bentley if you are interested in using this connector.
Synchronization API
You can also use the Synchronization API (https://developer.bentley.com/apis/synchronization/overview/) to synchronize data to an iModel. The list of supported applications and formats that are supported using the API is available here: https://developer.bentley.com/apis/synchronization/supported-formats/
How to work with file types, which use the MicroStation Connector?
Some file types are listed as being supported by "MicroStation" under the connector type and these can be synchronized directly with the MicroStation Connector. Examples of this are FBX, OBJ and SKP. Other file types that are listed as "MicroStation (via dgn)" must first be imported into MicroStation and saved as a dgn, then the MicroStation Connector can be used to synchronize the dgn into an iModel.
Note for .imodel files, they must be referenced into a DGN file and then an i.dgn must be produced in order for the model to be imported with the MicroStation Connector. Support for .imodel 1.5 and 1.6 versions will be dropped with MicroStation CONNECT Edition Update 17.
Reality Data Support
Reality data, like point clouds and reality meshes, can be viewed along with your engineering data.  There are no iModel Connectors to sync reality data, instead use Bentley ContextCapture to add real-world digital context to your iTwins.
For more information on how to associate your reality data to an iTwin go to the [[Reality Data with Context Share]] page.
GeoSpatial Data Support
The GeoConnector is being developed to support geospatial data coming from multiple sources.
Presently, Shapefile, PostGIS database, ESRI File Geodatabase, ArcGIS Feature Service, and WFS(Web Feature Service), KML/KMZ, GeoJSON and Oracle Spatial and SQL Spatial database formats are supported.
For more information on how to use the GeoConnector, visit the GeoConnector page.
Autodesk Materials Support
The Autodesk Material Library consists of several sub-libraries and installers (MSI files) can be taken from installers for Revit, 3dMax or AutoCAD.
Or they can be downloaded separately from the Autodesk site: https://knowledge.autodesk.com/support/infraworks/learn-explore/caas/CloudHelp/cloudhelp/ENU/IWGettingStarted/files/Install/IWGettingStarted-Install-ToInstallAutodeskMaterialLibraries-html-html.html (all resolutions packages are necessary but first Common package isn’t).
It is better to install all Base, Low, Middle, and Advanced Image libraries. At least Base, Middle, and Advanced has unique files.
Materials should be exported to i-model automatically if Autodesk Materials are installed on the machine where the iModel Connector job is executing from.
File formats supported by Navisworks
Navisworks can be used to import the additional formats listed below. This of course requires that the source file is first loaded into Navisworks and then saved as a nwd file. Some formats are not listed in this table such as dgn, dwg, or ifc as examples. When a connector exists for a specific format, the best option is to use the native connector for that file format. However, for instances where a native connector does not exist for that format, using Navisworks for one of the formats listed below can be an option. The listed formats below have been tested and successfully imported into an iTwin from Navisworks.
File Format Source Application
asm Solidedge Assembly
asm Pro/ENGINEER Assembly
catpart CATIA V5 Part document
dri PDS
dwf Autodesk
dwfx Autodesk
iam Autodesk Inventor
igs IGES exchange format
ipt Autodesk Inventor
model CATIA V4 model
prt SolidWorks
prt NX
prt Pro/ENGINEER
pts Leica
ptx Leica
rte Revit
rvm RVM
wrl VRML
x_b Parasolid binary
