| Product(s): | OpenPlant Isometrics Manager in CONNECT Edition |
| Version(s): | 10.10.01.XXX |
| Environment: | Windows 10 (64-bit) |
| Area: | Configuring the BOM and Reports |
| Subarea: | - |
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
User is using some components for which special information like Stamp informing about those components should be added in generated isometrics model. Whole this process should be automated and if drawing contains those special components, then required stamps always should be placed in Isometrics.
- Open Project Administrator. Select Root and Project, Settings, and Isometric Styles.
- Choose Isometric Style, select Style Config Root, select config, and select report.def.
- In report.def file create new Report for Bolt Stamp and Save.
# A STAMP for BOLTS
REPORT = BOLT_STAMP
INCLUDE = EC_CLASS=BOLT
COLUMN = 10: W :
TEXT = @ STUD BOLTS 1-1/4" AND LARGER
TEXT = @ TO BE HYDRAULIC TENSIONED
TEXT = @ PER SPEC.
Write =
NODE = 71
END
- In isoseed.dgn file, select Place Text Node and activate Text Nodes under View Attributes.
Note: Place the Text Node in desired location. Deactivate Text Node visibility and close OpenPlant Isometrics Manager.
- Generate Isometrics model again and verify the results.
INCLUDE Size condition
There is a requirement to place a stamp for bolts that are 1-1/4" and larger. We can add rule to include only the bolts with size of 1-1/4" or larger.
- Open the same report.def file and include the line to add stamp for isometric models that contains EC_CLASS=BOLT equal or larger than 1 1/4"
# A STAMP for BOLTS
REPORT = BOLT_STAMP
INCLUDE = EC_CLASS=BOLT && SIZE2>1.25
COLUMN = 10: W :
TEXT = @ PER SPEC.
Write =
NODE = 71
END
- Generate Isometrics model. Stud bolts having smaller size and stamp will not be visible.
Include Another Stamp
If the model has two types of special components, both stamps can be placed on same location. To achieve this new report for new component type must be created and combined with previously created one.
- Open the same report.def file and apply the given values.
# A STAMP for BOLTS
REPORT = BOLT_STAMP
COLUMN = 10: W :
TEXT = @ PER SPEC.
Write =
#NODE = 71
END
- Create new report ELBOW_STAMP
# A STAMP for ELBOWS
REPORT = BOLT_STAMP
INCLUDE = EC_CLASS=ELBOW && SIZE1>1.25
COLUMN = 10: W :
TEXT = @ ELBOWS 1-1/4" AND LARGER
TEXT = @ PER SPEC.
Write =
END
- Create new report STAMPS
# Combined BOLTS and ELBOWS stamps
REPORT = STAMPS
WRITE = BOLT_STAMP
WRITE = ELBOW_STAMP
NODE = 71
END
- Generate Isometrics containing both component types and verify the results.
communities.bentley.com/.../how-to-insert-a-custom-weld-report-in-isometric-sheet
communities.bentley.com/.../how-to-generate-reports-based-on-size
communities.bentley.com/.../how-to-reclaim-desired-text-node
Comments or Corrections?
