| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): | 10.10.01.XXX |
| Environment: | Windows 10 (64-bit) |
| Area: | Ribbon Customization |
| Subarea: | Custom Ribbons |
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
If the user wants to add ribbon to access easily the commonly used components in Component Gallery. This will be helpful for having organized components in one ribbon.
