Applies To | |
Product(s): | OpenPlant Isometrics Manager in CONNECT Edition |
Version(s): | 10.XX.XX.XXX |
Environment: | Windows 10 (64-bit) |
Area: | Settings/Attributes |
Subarea: | - |
Original Author: | Evander Cabalagan, Bentley Global Technical Support |
In case the user wants to place a logo in the title block for ownership and standard, this article explains how to do it by following the steps below.
1. Open a seed file in OpenPlant Isometrics Manager.
2. Proceed to Attach Tools and select References.
3. In Tools, select Attach. Browse for the desired image/logo and select Open.
4. In Standard Views, select Top and OK. Drop the image/logo inside the template.
5. Select the file and Scale Reference.
6. Input a desired scale value then click somewhere or in an open space to take effect the scale.
7. Verify the result and move the image/logo to appropriate position.
