| Applies To | OpenPlant CONNECT Edition | ||
| Product(s): | OpenPlant Modeler | ||
| Version(s): | CONNECT EDITION (10.11.xx) | ||
| Environment: | Windows 8.1/10 (64 bit) | ||
| Area: | Pipe | ||
| Subarea: | |||
| Original Author: | Joseph Gelacio, Bentley Product Advantage Group |
There can be more than one segment under one pipeline if the model is imported from another tool. This may result in various issues. In this scenario you can create new Pipelines for multiple segments and updates the ECExpression of related components.
Note: The new pipelines are created based on the following conditions :
If all the segments are empty in a pipeline, keep the first segment and delete others.
Read-only / referenced out pipelines are not processed. A log file is generated for such pipelines typically at "C:\Users<UserName>\AppData\Local\Bentley\Logs\OpenPlantModeler.log"
