| Product(s): | OpenPlant PID CONNECT Edition |
| Version(s): | 10.11.00.213 and above |
| Environment: | Windows 10 (64-bit) |
| Area: | Customization |
| Subarea: | Modification |
| Original Author: | Sameer Bagwan, Bentley Global Technical Support |
This document explains the procedure to add Middle to Tie-In Symbol and a way to modify text in it.
To Modify the bubble type Tie-in please refer the steps mention in the below mentioned wiki article.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
