| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): |
10.09.02.11 & Above |
| Environment: | Windows 10 (64-bit) |
| Area: | Piping Network System |
| Subarea: | Pipeline |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
While Launching OpenPlant Modeler and trying to place the male Pipe Adapter, it is observed that Eccentric graphic has been placed instead of Concentric one. This document will explain how to get rid of this issue.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
