Applies To | |
Product(s): | OpenPlant Support Engineering |
Version(s): | 10.11.00.163 |
Environment: | Windows 10 (64-bit) |
Area: | Customization |
Subarea: | |
Original Author: | Sameer Bagwan, Bentley Global Technical Support |
The purpose of this document is to provide instructions on how change color of Supports in OPSE.
- Launch DB Browser.
- For the demonstration purpose modification are done in OOTB Metric environment. Click on Open Database and open OPSEMetric.db, mentioned below is the default location for it.
C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\WorkSpaces\OpenPlantExample\WorkSets\Metric\Standards\OpenPlant\ApplicationDb
- Select “Browse Data” tab and under Table dropdown “sysVisuals”.
- Do the changes as shown in below image select the required class and level, for testing purpose the color number is selected as “4”, on behalf of it user can choose any color number as required.
- Go to files and click on Save all. Relaunch OPSE and put a new support to verify the changes.
Note: The modification is only doable for new supports but not for already placed supports.
Still a problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
