How to Create Custom Cell in OpenPlant Isometrics Manager-CE
Product(s):OpenPlant Isometrics Manager CONNECT Edition
Version(s):10.XX.XX.XXX
Environment:Windows 10 (64-bit)
Area:Settings/Attributes
Subarea:
Original Author:Evander Cabalagan, Bentley Global Technical Support
Background:
Custom.cel has the higher priority to read when generating isometrics. Previously created cells in custom.cel can be use in higher versions of OPIM. This method is more advisable to apply than in lisocomp.cel. Kindly follow the given steps below on how to create a custom cell.
  1. Open Custom.cel in OpenPlant Isometrics Manager.
  2. Once Custom.cel is open, select Models under Primary and import Lisocomp.cel.
  3. Select one reference for any given cells.
  4. Rename the new cell according to the requirement.
  5. Modify the graphics and reposition the points if needed.
    Note: Avoid changing the color, weight and level of the points.
  6. Save and verify the result.
See Alsocommunities.bentley.com/.../modifying-symbols-in-openplant-isometrics-manager
Comments or Corrections?
