| Product(s): | AutoPLANT Modeler CONNECT Edition |
| Version(s): | 10.XX.XX.XXX |
| Environment: | Windows 10 (64-bit) |
| Area: | Errors, Logs, Messages, Crashes |
| Subarea: | - |
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
There are some situations where Runtime Error and Script Execution Error exist when placing Dummy Leg and Trunnion Support. Normally, it happens when there’s an issue with the spec. Hence, spec should be fixed and apply it to a certain line number or pipeline. Kindly follow the steps below to eliminate the errors.
Bentley's Technical Support Group requests that you please confine any comments you have on this Wiki entry to this Comments or Corrections?" section. THANK YOU!
