| Version(s): | CONNECT Edition (10.11.00.260) |
| Environment: | Windows 10 (64 bit) & Above |
| Area: | Consistency Checker |
| Subarea: | PlantSight Integration |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
To a PlantSight integrated OpenPlant workset, user has created process drawing & synced to PlantSight. Also, 3D components have been placed into OpenPlant Modeler with the same component details as per process drawing or P&ID drawing. In this article we will show the steps to see the same details present in OpentModeler and OpenPlnt PID.
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
