How To Create Region with and without Cutout Area around Texts-CE
Product(s):OpenPlant PID CONNECT Edition
Version(s):10.1*.**.***
Environment: Windows 10/11 (64 bit)
Area: Drawing
Subarea: Groups
Original Author:Álvaro Melgarejo, Bentley Global Technical Support
In a drawing, when there is any closed shape with text within it, and the command Create Region is used with a fill type other than "None", there is an option to enable and disable a cutout area around the text.
  1. Launch OpenPlant PID CONNECT Edition.
  2. Draw a closed shape.
  3. Place any text inside.
  4. Select the command Create Region.
  5. Notice the button with a tooltip "Locate Interior Text". Toggle on or off as desired:
  6. Click inside the closed shape.
  7. Click anywhere on a blank part of the design to finish applying the region.
    Below, the two possible outcomes:
