| Key: | |
| CS – Client Server Article | FAQ – Frequently Asked Questions |
| TB – Technical Bulletin | TN – TechNote |
| VID – SELECTsupport Video |
AutoPLANT Isometrics can produce intelligent isometric drawings using spec-driven piping design with advanced routing and editing features. You can also create intelligent isometrics from your AutoPLANT PIPING models with the AUTO-ISO utility. The automatic generation of isometrics includes the capability to automatically generate and place annotation, dimensions, Bill of Materials, and to select drawing data manually or in batch mode. You can also use AUTOISO to separate your ISOMETRICS’ drawings into separate drawing sheets.
communities.bentley.com/.../4342.autoplant-isometrics
Bentley's Product Advantage Group welcomes any and all comments you have on this Wiki entry, as long as they are posted in the "Comments" area below. THANK YOU!
