| Key: | |
| CS – Client Server Article | FAQ – Frequently Asked Questions |
| TB – Technical Bulletin | TN – TechNote |
| VID – SELECTsupport Video |
AutoPLANT Piping gives you spec-driven 3D piping design with advanced routing and editing features. Drawing production includes orthographic drawings (plans, elevations, and sections), using paper space view ports and exporting 3D model data to produce finished isometric drawings. Fully featured automated isometric drawing production features are included in the piping application. No additional licensing is required. Drawing Flattener produces flat, 2D drawings including elevations, plans, and sections from the 3D model. AutoPLANT Piping works seamlessly with other Bentley plant design and data management applications via the shared plant project database.
Bentley's Technical Support Group welcomes any and all comments you have on this Wiki entry, as long as they are posted in the "Comments" area below. THANK YOU!
