| Key: | |
| CS – Client Server Article | FAQ – Frequently Asked Questions |
| TB – Technical Bulletin | TN – TechNote |
| VID – SELECTsupport Video |
Using AutoCAD with an external relational database environment, Bentley's AutoPLANT P&ID creates intelligent plant schematics. With it, engineers can learn more about their plant design in a fraction of the time required to study hundreds of layout drawings or 3D models.
This cost-efficient application reduces the design and documentation time for capturing process information for system design and plant studies (such as HAZOP studies), ensuring compliance to OSHA 1910 and ISO standards. Through its scaleable design, AutoPLANT P&ID is suitable for large, midsized and small engineering companies and plant operators, providing a key tool for the lifecycle design and documentation of process plants.
Bentley's Technical Support Group welcomes any and all comments you have on this Wiki entry, as long as they are posted in the "Comments" area below. THANK YOU!
