| Key: | |
| CS – Client Server Article | FAQ – Frequently Asked Questions |
| TB – Technical Bulletin | TN – TechNote |
| VID – SELECTsupport Video |
Bentley Vision is a plant knowledge management application that provides seamless access to plant data and documentation through a single, easy-to-use interface. Vision's tag number- centric approach to data management puts the information you need at your fingertips. Select a tag numbered component from interface and all documents and data associated with the component are immediately available.
Bentley's Technical Support Group welcomes any and all comments you have on this Wiki entry, as long as they are posted in the "Comments" area below. THANK YOU!
