| Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
| Version(s): | 10.XX.XX.XXX |
| Environment: | Windows 10 (64-bit) |
| Area: | Settings/Attributes |
| Subarea: | - |
| Original Author: | Evander Cabalagan, Bentley Global Technical Support |
Showing the piping component’s tag especially for valves is necessary in OpenPlant Isometrics Manager. It serves as identity in the drawing and much needed in actual assembly. Kindly follow the given steps on how to make the user label or tag visible in generated isometrics.
Provide the details or create a component tag for valve.
