| Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
| Version(s): | 10.XX.XX.XXX |
| Environment: | Windows 10 (64-bit) |
| Area: | Settings/Attributes |
| Subarea: | Modifying Symbols |
| Original Author | Evander Cabalagan, Bentley Global Technical Support |
There is a user requirement to change the symbol or appearance of flexible hose in generated isometrics. Normally, this issue happens in old versions of schemas.
Note: This is AutoPLANT Modeler to OpenPlant Isometrics Manager workflow.
communities.bentley.com/.../edit
Comments or Corrections?
