To Update the Pipeline Number When Generating New ISO-CE
Product(s):OpenPlant Isometric Manager
Version(s):
CONNECT Edition 10.11.++
Environment: Windows 10/11 (64-bit)
Area: Workflow
Subarea:
Original Author:Joseph Gelacio
Users notice that modification in the pipeline is not reflecting properly in the generated Isometric.
In this wiki article, shows the correct workflow when generating new Isometric after some modifications in the model.
  1. Launch Pipeline Manager, select the Pipeline and generate the Isometric.
  2. Isometric will be generated successfully.
  3. If you make any modifications in the model or pipeline, always make sure to close the open OPIM window before generating a new Isometric.
OpenPlant Isometrics Manager is not directly on sync on any changes you make in OPM Pipeline. OPIM needs to closed and restart to refresh the data that it is reading from OPM Pipeline.
communities.bentley.com/.../how-to-add-the-reattach-instrument-bubble-and-annotation-option-in-the-openplant-pid
