| Product(s): | OpenPlant Isometric Manager CONNECT Edition |
| Version(s): |
10.10.01.16 |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Output Format |
| Subarea: | PDF Plot |
| Original Author: | Fer Mykiel Gonzales,Bentley Technical Support Group |
When generating an isosheet, a PDF output can be set in a style and the default paper size is A2. The user wants to change this to an A1 paper size.
1. Open the plot.cfg in Notepad. This file can be located in %WorkSpace_Location%\WorkSets\%WorkSet_Name%\Standards\OpenPlant\Isometrics\styles\%Style_Name%\config\
2. Scroll down to the bottom of the page
3. Enter the following:
print papername ISO A1
print maximize
4. Save the file.
5. Open OPIM Style Editor
6. Set the style and PDF in the Output Format then Save.
If above problem still persists, then please create a Case and contact the Bentley Technical Support group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
