How to Fix Spool Label, Flipped Upside Down while moving in Isometric Modeler-CE
Product(s):OpenPlant Isometric Manager
Version(s):
10.11.00.260
Area: OpenPlant Modeler & OpenPlant Isometric Manager
Subarea: XXXX
Original Author:Chanchal Mashalkar, Bentley Global Technical Support
In some situation After, generating an isometric for spool vertical pipeline, the spool label might get flipped upside down as shown in the figure below.
Following are the steps to fix this condition.
  1. Launch OpenPlant Modeler in open .dgn file.
  2. Isolate the specific pipeline as shown in figure.
  3. Move the branch pipeline upward (Drag to Flip) and roll back to its original position as shown in image.
  4. While doing above procedure there is a possibility of dis-connectivity so check the connectivity if something is missing then fixed the connection.
  5. Generate an isometric and observed that the isometric move label woks properly and there will be no flipped label while moving.
Still a Problem?
