| Product(s): | OpenPlant Isometric Manager |
| Version(s): | CONNECT Edition (10.11.0.175) |
| Environment: | Windows 10 (64 bit) & Above |
| Area: | Processing |
| Subarea: | PCF File |
| Original Author: | Chanchal Mashalkar, Bentley Global Technical Support |
In OpenPlant Isometrics Manager, PCF file will be generated for other systems software and hence it is required to have desired attributes inside the PCF file. Below steps illustrates adding the new attributes inside the file. Below content has been described in context with OpenPlant Modeler and OpenPlant Isometrics Manager.
Path to follow the default style IFC:
C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\WorkSpaces\OpenPlantExample\WorkSets\Metric\Standards\OpenPlant\Isometrics\styles\IFC\config
To Add Component Tag Data
Bentley's Global Technical Support Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
