How to Rotate the Table Header in Reports OPPA-CE
Product(s):OpenPlant Project Administrator CONNECT Edition
Version(s):
10.XX.XX.XX
Area: Reporting Designer
Subarea:
Original Author:Fer Mykiel Gonzales,Bentley Technical Support Group
Brief Description:
Change the orientation of the Table Header to vertical.
1.Launch OpenPlant Project Administrator
2. Go to the Workspace > Workset location and select which product the report is associated to. Select Reporting Designer
3. Select the report you wish to modify then select the Header
4. In the Property Grid, change the Angle to 90 or 270 to implement vertical orientation
5. Change the size of the cell to fit the Text
6. Save the report modified.
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Technical Support group.  Please include a list of all relevant details to get in depth analysis for a solution or workaround
